Software Archive
Read-only legacy content
17060 Discussions
Problems installing Composer XE Fortran
Hermann_Zeyen
Hi, It seems that there is a small bug in the installation procedure of the last Composer XE Fortran installer (w_fcompxe_novsshell_2011.1.127). While the C-installation allows to overwrite the older version, the Fortran installation does not allow me to do that, it creates without choice a new subdirectory and a second copy of the Fortran. Sure, I could intall C also in the same new subdirectory and everything works fine, however it would be good to allow coherent behaviour of both installations. All the best, HZ
Hubert_H_Intel
I'll have a look at this and give you an answer soon.
Regards, Hubert.
Hubert_H_Intel
Sorry for the delay. I did a couple of investigations with the Intel Visual Fortran Composer XE for Windows*, but couldn't detect any problem. Both the alternative Installation as well as an update installation (where the Compoxer XE Update 1 replaced the initial release) worked fine.
Could you please provide more info about the OS and evnrionment. Maybe this is an issue with a special system configuration only.
Hubert.
Hermann_Zeyen
Hi Hubert,
I am using Windows 7 professional 64 bits and I don't use the standard emplacement but want to install it on the D: disk. As I said, no problem installing the C compiler, but the Fortran simply didn't give me an option, even when I told it to do a user controlled installation (which in the former version was not necessary if the C compiler was installed first).
Cheers, Hermann
Hubert_H_Intel
Hermann,
Which is the version of Visual Studio you have installed on your machine? Do you have more Visual Studio versions installed (2005, 2008 and/or 2010)?
Hubert.
Hermann_Z_
I am using Visual Studio 2010. Since I just reinstalled the whole system, there shouldn't be any trace of 2008 (the one integrated with Intel Fortran) left.
However, I don't think it has to do with Visual Syudio. The question where I wanted to install the new version simply didn't appear and this should be before the installer even asks about the VS version.
Hermann
Hubert_H_Intel
Hermann,
I just finished a test installation on a fresh machine. I installed the C++ Composer XE and replaced this by the Comoser XE Update 1. The installation gave me the choice to either keep the initial version or overwrite it. I did an overwrite. Then I installed the Fortran Composer XE and then the Fortran Comoser XE Update 1, but here the installater didn't give me the choice to overwrite the initial Fortran installation; it installed the Update 1 side-by-side with the initial version. So it's true what you encountered. Thanks for submitting this finding. I'm going to file a defect for the installer.
Until this will be fixed by a newer update I think there is no real problem. Just make sure that the Fortran Update 1 is active (in Visual Studio go to Tools > Options > Intel Visual Fortran > Compilers and select the right version (here: Intel Compsoer XE 2011 Update 1 build 127).
Does this help?
Hubert.
Hermann_Z_
Hi Hubert,
What I did, I installed both C and Fortran in a new directory. Yes, it is no real problem (except for disk space and having to remove manually the old version). I only wanted to mention this problem so you are aware for the next update. Thanks for your attention.
H.
Hubert_H_Intel
Hermann,
A defect was filed against the Fortran install problem and will be fixed in one of the next updates. Thanks for bringing this up!
Hubert.
