Software Archive
Read-only legacy content
17060 Discussions
Problems installing plugin admob third party
Juan_Manuel_S_
Hi people, everytime i try to build a proyect with the pluggin from third party admob pro (com.google.cordova.admob) it gaves me an error (Error: Plugin "AdMob Plugin Pro" failled to install), everytime the same error, it doesn't matte if it's my own proyect or a template from the own intel xdk, i'm using Cordova 5.1.1 and Intel XDK 2727, it's suppose to working just fine, i don't know where could be the problem, anyone can help me with this? Thanks
Michael_O_2
Dear Juan,
Use CLI 4.1.2 and add this plugin from the 'third party' section on the plugins tab: com.cranberrygame.phonegap.plugin.ad.admob
Juan_Manuel_S_
Hi, i can instaló the other admob bit i really need the admob pro forma muy proyecto because of my proyecto configuration. I'm adding the plugin via, cordova plugin, third party, and adding com.google.cordova.admob and then when i press ok it searches and selecto it automatically, but the gaves me the error i mention before, i try my proyect and the admob template from the xdk, also with cli5.1.1 and 4.1.2. Can you explain me how to make it vía XML and i can try if that way it works? Thanks
Juan_Manuel_S_
Solved by downloading the plugin into my computer and then upload to intel xdk. That way is not error instaling :D
