Software Archive
Read-only legacy content
17060 Discussions
Problems with Intel License Manager for FLEXlm
Andreas_Bleier
I can start a license server, but the vendor deamon always fails:
17:20:04 (lmgrd) pid 2156
17:20:04 (lmgrd) Done rereading
17:20:04 (lmgrd) FLEXnet Licensing (v11.10.0.0 build 95001 x64_n6) started on SRVDOM01 (IBM PC) (4/13/2012)
17:20:04 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
17:20:04 (lmgrd) US Patents 5,390,297 and 5,671,412.
17:20:04 (lmgrd) World Wide Web: http://www.flexerasoftware.com
17:20:04 (lmgrd) License file(s): C:\\Program Files (x86)\\Common Files\\Intel\\Licenses\\COM_W_CMP_FOR_G4BB-92MCRS48.lic
17:20:04 (lmgrd) lmgrd tcp-port 28518
17:20:04 (lmgrd) Starting vendor daemons ...
17:20:04 (lmgrd) Started INTEL (pid 412)
17:20:04 (INTEL) FLEXnet Licensing version v11.10.0.0 build 95001 x64_n6
17:20:04 (INTEL) EXITING DUE TO SIGNAL 32 Exit reason 9
17:20:07 (lmgrd) INTEL exited with status 32 (Exited because another server was running)
17:20:07 (lmgrd) MULTIPLE "INTEL" license server systems running.
17:20:07 (lmgrd) Using Task Manager, stop INTEL and run lmreread
17:20:07 (lmgrd)
17:20:07 (lmgrd) This error probably results from:
17:20:07 (lmgrd) 1. Another copy of the license server manager (lmgrd) is running.
17:20:07 (lmgrd) 2. Another copy of the vendor daemon is running.
17:20:07 (lmgrd) 3. The locking mechanism(s) were removed by an
17:20:07 (lmgrd) outside program.
17:20:07 (lmgrd)
17:20:07 (lmgrd) Rereading license file... Requested from wwwklub@srvdom01
17:20:07 (lmgrd) Reread: Started INTEL (pid 4708)17:20:07 (lmgrd) Done rereading
17:20:07 (lmgrd) ...Finished rereading
17:20:07 (INTEL) FLEXnet Licensing version v11.10.0.0 build 95001 x64_n6
17:20:07 (INTEL) EXITING DUE TO SIGNAL 32 Exit reason 9
17:20:12 (lmgrd) INTEL exited with status 32 (Exited because another server was running)
17:20:12 (lmgrd) MULTIPLE "INTEL" license server systems running.
17:20:12 (lmgrd) Using Task Manager, stop INTEL and run lmreread
17:20:12 (lmgrd)
17:20:12 (lmgrd) This error probably results from:
17:20:12 (lmgrd) 1. Another copy of the license server manager (lmgrd) is running.
17:20:12 (lmgrd) 2. Another copy of the vendor daemon is running.
17:20:12 (lmgrd) 3. The locking mechanism(s) were removed by an
17:20:12 (lmgrd) outside program.
17:20:12 (lmgrd)
It some how seems to think another server is running, but there is no INTEL process in the task manager.
I tried reinstalls, reboots, adjusting the INTEL_LICENSE_FILE variable but nothing has so far worked. It is a virtual machine running Windows 2008.
Any help would be awesome!
Have a great weekend!
Martin
mskinner2
See my post responding to Teresa Ford's similar problem http://software.intel.com/en-us/forums/topic/266588#comment-1716549
KitturGanesh
Thanks mskinner2. This was also resolved offline... Regards, Kittur
