Software Archive
Read-only legacy content
17060 Discussions
Procedure entry point error message
cainlord
When running my program I get the following error message under F90 6.5 :
"the procedure entry point __msportlib_d_fseek_i8 could not be located in the dynamic link library DFORMD.DLL"
Under version 6.6A I don't receive this error message . This occurs under Windows NT and 2000. Any Ideas towards correcting the problem without upgrading to 6.6A (would take awhile for my end users to have this version).
Download and run VFRUN66AI.EXE on the end user machines. This will install the 6.6A run-time DLLs only.
Steve
cainlord
So there is no way around this other than installing new DLLs?
Not if you are linked against the DLL form of the run-time library. If your program is an EXE, you can select Single-threaded as the library type, and then you'll link to the static library and not be dependent on the DLL.
Steve
