Software Archive
Read-only legacy content
17060 Discussions
Profile events on xeon by using perf
Iris_L_
I am doing some experiments using xeon and make a comparison between xeon and AMD, I am using perf in both machines. My concern is that the results of my events in xeon are thousand times higher then the results from AMD, but the runtime on xeon is much better than the AMD. I am measuring cache, instructions and cpu-clock in both machines.
My application is a matrix multiplication, size 1000x1000 and I am running a sequential execution, not parallel yet.
Can you explain why these differences (thousand times) between the machines? for example, in AMD caches-references =   713,432 and xeon is  127,708,365 caches-references.
this is the xeon configuration
  • Model: Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz
  • CPU MHz: 1200.000
  • CPU cores per Processor: 8
  • Host Physical Memory: 65933 MB
  • Architecture: x86_64
  • L1 dcache: 32K
  • L1 icache: 32K
  • L2 cache: 256K
  • L3 cache: 20480K
  • cache_alignment: 64
this is AMD configuration
AMD Opteron 2427
  • Instruction set: x86-64
  • Speed2.2 Ghz
  • L1 instruction cache6 x 64 Kb
  • L1 data cache6 x 64 Kb
  • L2 cache6 x 512 Kb
  • L3 cache6 Mb
take a look in this example,
=== results from AMD ======
perf stat -e cache-references,cache-misses,branch-instructions,cpu-clock bpsh 15 ./mm1 1000 1
Program runs in 17.52 seconds
 Performance counter stats for 'bpsh 15 ./mm1 1000 1':
           713,432      cache-references
            35,538      cache-misses              #    4.981 % of all cache refs
           411,916      branch-instructions
          2.701875      cpu-clock (msec)
      17.560428347 seconds time elapsed
=== results from Xeon ======
now, I compiled mm1 on xeon as offload, but there is no #pragma offload directive, so the code run intirely on xeon (processor)
perf stat -e cache-references,cache-misses,branch-instructions,cpu-clock ./mm1 1000 1
Program runs in 2.69 seconds
 Performance counter stats for './mm1 1000 1':
       127,708,365      cache-references
           477,245      cache-misses              #    0.374 % of all cache refs
       507,201,088      branch-instructions
       2701.183114      cpu-clock (msec)
       2.701594439 seconds time elapsed
do you have any idea why the results are so different?
thanks,
