Software Archive
Read-only legacy content
17060 Discussions
Prompt command failed [ Cordova ]
João_Carlos_Cordeiro
I used the Cordova Library command prompt and an error occurred.  Does anyone know why? Thanks ...
Command :
navigator.notification.prompt(
    'Please enter your name',  // message
    onPrompt,                  // callback to invoke
    'Registration',            // title
    ['Ok','Exit'],             // buttonLabels
    'Jane Doe'                 // defaultText
Error :
Notification.prompt
The program under test has called the native part of a Cordova plugin that is unknown to the emulator.
It appears that we are missing emulation for that API.
Push the Fail button to continue the API by calling the fail callback.
Push the Success button to continue the API by calling the success callback.
Elroy_A_Intel
The emulator won't display this prompt because it doesn't have the appropriate functionality to render the expected user experience. You will need to test this functionality on a real device.
Thank you so much, Elroy.
