These questions were received by Intel Software Network Support about the Intel Performance Power Monitor Plug-in for Google Desktop, followed by the responses received:
Q. Will this work on AMD processors?
A. Yes, this will work on most AMD processors, there is nothing included that is Intel-specific.
Gina B.
http://www.intel.com/software
email: ISN.support@intel.com
Intel is a registered trademark of Intel Corporation or its subsidiaries in the United States and other countries.
*Other names and brands may be claimed as the property of others.
When I typed in "regsvr32 /u IntelPPW.dll", I got the error message "The module IntelPPW.dll was loaded, but the call to DllUnregisterServer failed with error code 0x80070005".
I guess Google Desktop Sidebar was installed correctly, becauseother Gadgets are working excellent.
The type of Operating System isGenuine Windows Vista Home Premium, the type of laptop is Toshiba Satellite A215-S4697.
I appreciate you desire to help me, thank you!
thanks
--Rich
But I don't know why The discharge rate is 0 and I can't see time remaining...
Thanks! Alex
Sorry about the hassle, I haven't seen this problem as of yet. So here is what we can try. Click on the down arrow of the gadget "v" and then the options. then click on view log. The log should have both and the drain rate graphs. see if they get updated when you plug-in and out the power. if it doesn't then maybe the security is blocking the battery update as well. just a guess since I haven't tried this without admin rights. I will. Does your cpu utilization and frequency work? thanks for finding the problems everything helps.
--R
--R
--R
Richard,
I had the initial problem with registering the .dll. Your fix worked but the gadget would still not show up in the side bar. So, I turned off windows UAC. The gadget installed fine and shows up. Only issue is that it doesn't show the charge/discharge variable which is why I installed this gadget (and google desktop) in the first place.
Is there a standalone intel application that does this? I don't need google desktop...
To answer your question earlier with:
The log does not update. No matter whats going on the charge rate is 0 and the drain is 20-22. CPU utilization does work. Frequency shows a number. However, when I change my battery usage to "On the Road" or a mobile setting, the frequency should decrease but it doesn't. So not sure if the frequency is correct at all times.
