Software Archive
Read-only legacy content
17060 Discussions
Qt library and STL offload
MK1
Hi, I'm developing an application using Qt framework and I have some difficulties using STL in offload region. As an example:
#pragma offload_attribute(push, target(mic))
#include <algorithm>
#pragma offload_attribute(pop)
void main()
float a = 0.1f; float b = 0.5f; float c = std::max(a,b);
#pragma offload target(mic)
 float x = 0.1f; float y = 0.5f; float z = std::max(x,y);
This compiled without error. But if I include <QObject> before #pragma offload_attribute I get following error:
undefined reference to 'float const& std::max<float>(float const&, float const&)'
So I guess, that <algorithm> is included in <QObject> library and therefor not linked with mic code. But when I change the order and include <QObject> after <algorithm> I'm experiencing another errors:
function has not been declared with compatible "target" attribute
*MIC* function has not been declared with compatible "target" attribute
undefined reference to 'std::operator|=(std::_los_Fmtflags&, std::_los_Fmtflags)'
undefined reference to 'std::operator~(std::_los_Fmtflags)'
undefined reference to 'std::operator&=(std::_los_Fmtflags&, std::_los_Fmtflags)'
undefined reference to 'std::operator&(std::_los_Fmtflags, std::_los_Fmtflags)'
undefined reference to 'std::opreator&=(std::_los_Fmtflags&, std::_los_Fmtflags)'
undefined reference to 'QByteArray::swap(QByteArray&)'
undefined reference to 'QString::swap(QString&)'
There is no problem using for example <complex> library in offload since it is not included in Qt libraries. I don't need to use Qt classes within offload region, but I'd like to use some STL functions. Any suggestions?
Thanks MK.
Kevin_D_Intel
I reproduced part of this scenario by simulating <QObject> with a “QObject.h” containing only the statement:
Then adding the #include for this ahead of the offload_attribute which produces the error:
$ icpc -V
Intel(R) C++ Intel(R) 64 Compiler XE for applications running on Intel(R) 64, Version 15.0.1.133 Build 20141023
Copyright (C) 1985-2014 Intel Corporation.  All rights reserved.
$ icpc u539493.cpp
/tmp/icpcvbwuBX.o: In function `__offload_entry_u539493_cpp_10mainicpc2009569027UP9OAG':
u539493.cpp:(.text+0x52): undefined reference to `float const& std::max<float>(float const&, float const&)'
I have not been able to reproduce the second set of warnings/errors.
In the placing <QObject> ahead of the offload_attribute, could you conditional its inclusion based on the __MIC__ predefine as follows:
#ifndef __MIC__
#include <QObject>
#endif
TimP
The errors look as if there may be a problem in the link command, as icpc ought to link against libstdc++ automatically, while icc or ld would require an explicit reference to the library.
Otherwise, I wonder if this might be connected with the differences in treatment of std::max between icpc and g++.  While icpc likes to generate inline code (with the default options, such as Kevin quoted), g++ does not, and prefers fmaxf() with option -ffast-math (implying -ffinite-math-only).
The fmaxf() choice avoids the question of requiring C++ as opposed to C, but icpc doesn't offer an option like -ffinite-math-only to ignore the special requirements of fmaxf() so as to optimize it (which may not be important in the quoted context).
MK1
Thank you both for reply. I already tried placing <QObject> inclusion in #ifndef statement, but then I get error:
*MIC* identifier "QObject" is undefined
whenever I use QObject class. I thought MIC version of code is created only for parts within #offload statement, so I don´t really understand the previous error.
Kevin_D_Intel
Yes, target-compilation only creates an outlined function containing the offload code as part of the offload image; however, the compiler sees the complete source file during both the host and target compilations so that’s likely behind that latest error.
I’m not sure what might be a good solution for your case. A couple of ideas might be to:
  • move the offload code into a separate function and separate source file
  • #ifndef the host-code uses of QObject
MK1
Indeed moving the offload code into separate source file did the trick. I created separate class with offload computations and put whole class within #pragma offload_attribute statements. Now it is possible to call the class in #pragma offfload inside class derived from QObject.
Kevin_D_Intel
Great! Glad to hear that.
