Software Archive
Read-only legacy content
17060 Discussions
QueryFingerData
Scott_W_1
Could someone provide an example of using QueryFingerData?
I've been trying to piece it together from the documentation, but not having much success yet.
I'm able to use QueryTrackedJoint to output the realworld positions of each joint, but want to compare it with the foldedness state of each finger.
Ideally, I would like to iterate through each finger, record the finger label, then output the foldedness of each. I've been working within the tutorial, trying to modify it for finger data:
for(int i = 0 ; i < numOfHands; i++)
            // get hand joints by time of appearence
            PXCHandData::IHand* handData;
            if(outputData->QueryHandData(PXCHandData::ACCESS_ORDER_BY_TIME,i,handData) == PXC_STATUS_NO_ERROR)
                PXCHandData::FingerData FingerData;
                //PXCHandData::JointType jointType;
                // iterate through fingers and get finger data
                for(int j = 0; j < PXCHandData::NUMBER_OF_Fingers ; j++)
                      //pseudocode below
                       handData->QueryFingerData(j,fingerdata);
                       //insert code to output data here similar to line below for jointdata
                       //std::printf("Tracked Joint: %i, X: %2f, Y: %2f, Z: %2f \n",j, jointData.positionWorld.x, jointData.positionWorld.y, jointData.positionWorld.z);
Jack_K_1
New Contributor II
Scott,
The attached archive contains two C++ files: A modified main_hand_tracking_procedural.cpp (in the hand tracking tutorial) that has calls to routines in FingerUtils.cpp.
The basic idea is to map a hand joint to a finger and then call the appropriate routine to get the finger information.
Jack
Jack_K_1
New Contributor II
Scott,
Jack
Scott_W_1
Thanks! Perfect timing. I'm setting up a snapshot app to record hand poses. It currently can record the joint data. I'm now ready for the finger data.
