Software Archive
Read-only legacy content
QueryUserID
Brennon_W_
According to these docs:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/queryuserid_recognitiondata_pxcfacedata.html
An unrecognised user, should return -1.
I am getting an incremental UserID count from the same face being queried.
How is that possible?
Cheers
Brennon_W_
Answering my own question here for anyone else.
The registration mode will determine how users are added to the database.
REGISTRATION_MODE_ON_DEMAND is what should be used to have control over when new users are added.
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?recognitionregistrationmode_recognitionconfiguration_pxcfaceconfiguration.html
Cheers
Brennon_W_
Actually, scratch that - this appears to be just a bug?
Regardless of the setting, new registrations just occur automatically.
Brennon_W_
Ok.
This issue probably falls under the category of logical bug, because of the member function naming convention used in the SDK.
Because the designers of the SDK have used a pattern whereby Interface instances are returned through method queries, both "PXCMFaceData.Face" and "PXCMFaceData.DetectionData" types (sharing the same Interface type of PXCMFaceData) support the member function named of QueryUserID.
PXCMFaceData.Face.QueryUserID actually returns a FaceIdentifier, which is not documented at all.
PXCMFaceData.DetectionData.QueryUserID return correctly the UserID.
Intel: The descriptive name of the member function is nothing to do with the result. This should be corrected.
Xusheng_L_Intel
It was documented @https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/queryuserid_face_pxcfacedata.html, thanks!
