Software Archive
Read-only legacy content
17060 Discussions
Questions for the Intel RealSense SDK Java/Processing wrapper
GProf
I've just started playing with the F200 camera and I have a few initial questions as I began with the Java Wrapper:
  1. Is the Processing Wrapper the same thing as the Java library ? (It appears this way, but I could use a confirmation)
  2. How can I retrieve the Face landmarks using Java ? (snippet bellow)
  3. Can I use the heart rate features in Java ? If so, how ?
  4. Can I use the BlobModule in Java ? If so, how ? (snippet bellow)
  5. Where can I get an updated documentation (including what's currently supported or not in Java) ?
For Issue 2, retrieving facial landmarks, I've tried using both the non-grouped and grouped methods:
  1. int npoints = detectData.QueryNumPoints();
  2.             PXCMFaceData.LandmarkPoint[] points=new PXCMFaceData.LandmarkPoint[npoints];
  3.             detectData.QueryPoints(points);
  4.             println(points);
This returns an empty list, similar to retrieving grouped points (which returns true):
  1. int numPtsLE = detectData.QueryNumPointsByGroup(LandmarksGroupType.LANDMARK_GROUP_LEFT_EYE);
  2.             LandmarkPoint[] ptsLE = new LandmarkPoint[numPtsLE];
  3.             boolean hasLEPoints = detectData.QueryPointsByGroup(LandmarksGroupType.LANDMARK_GROUP_LEFT_EYE,ptsLE);
  4.             if(hasLEPoints){
  5.               for(int le = 0; le < numPtsLE; le++){
  6.               if(ptsLE[le] != null) ellipse(ptsLE[le].image.x,ptsLE[le].image.y,3,3);
  7.               }
  8.             }
  9.             println(hasLEPoints);
  10.             println(ptsLE);
prints
  1. true
  2. [0null
  3. [1null
  4. [2null
  5. [3null
  6. [4null
  7. [5null
  8. [6null
  9. [7null
  10. [8null
When setting up, I've enabled landmark using the PXCMFaceConfiguration instance:
  1. faceConfig.landmarks.isEnabled = true;
For issue 3, using hearRate, calling QueryPulse as the documentation suggests
  1. // cfg is a PXCMFaceConfiguration instance
  2. cfg.QueryPulse().Enable();
ends up with a NullPointerException
  1. Exception in thread "Animation Thread" java.lang.NullPointerException
  2.   at intel.rssdk.PXCMFaceConfiguration$PulseConfiguration.Enable(PXCMFaceConfiguration.java:335)
I was expecting to write something like
  1. faceConfig.pulse.isEnabled = true;
but pulse doesn't appear to be a property of PXCMFaceConfiguration
For issue 4, using the Blob Algorithm, I tried following the documentation:
  1. // Create an instance of the SenseManager
  2. PXCMSenseManager sm = PXCMSenseManager.CreateInstance();
  3.
  4. // Enable the blob module
  5. sm.EnableBlob();
  6.
  7. // Get an instance of PXCMBlobModule
  8. PXCMBlobModule blobModule = sm.QueryBlob();
but EnableBlob() isn't present. I'm guessing EnableModule(int,ImplDesc) might work,
but I'm not sure what arguments to pass. Again, QueryBlob() is missing (perhaps QueryModule(int) should be used) ? If so, how ?
Regarind issue 5, I'm trying to use as the SDK as much I can, but it would be a huge time saver
knowing what I can an can not use for now (and when to expect currently unsupported features).
I am using the latest Intel RealSense Drivers and SDK AFAIK:
Intel RealSense Depth Camera Manager F200 1.3.20.55679
Intel RealSense SDK 2014 5.0.3.187777
on Windows 8 (version 6.2, build 9200)
Thank you,
George
GProf
@CaptGeek (Intel) , @Colleen Culbertson (Intel) Has anyone encountered these issues with the Java wrapper ?
If so, how were these issues addressed ?
Thank you,
George
Alexander_L_Intel
There's no blob module done in Java in R3, and it most probably won't be in Java.
It is left in the doc - need to wipe off Java for blob.
GProf
Hi Alexander,
Thank you for getting back.
Can you please advise on using Face Landmarks and Pulse using the Java API ?
Thank you,
George
