Software Archive
Read-only legacy content
17060 Discussions
Quickwin program not showing on Taskbar
Intel_C_Intel
I have created a modal dialog based program but I can't get it to show up on the Windows Taskbar or Alt+Tab taskswitching key. Can someone point me in the right direction. Thank you.
Jugoslav_Dujic
Valued Contributor II
That will happen if dialog's parent is a hidden main window (hidden windows do not show up on taskbar and task list). Note that for a dialog-based application you don't have to have any windows except for the main dialog.
However, QuickWin creates the main frame window by default and you can't do much about it. I suggest you turn your project into a Win32 application; actually, that will simplify it since you don't need any QW overhead -- all you need is already in DFLOGM:
INTEGER FUNCTION WinMain(hInst,hPrevInst,lpCmdLine,iCmdShow)
!DEC$ATTRIBUTES STDCALL, ALIAS: "_WinMain@16" :: WinMain
USE DFLOGM
TYPE(DIALOG):: Dlg
INCLUDE "Resource.fd"
iret = DlgInit(IDD_SOMETHING, Dlg)
iret = DlgSet(Dlg,...)
IF (DlgModal(Dlg).EQ.IDOK) THEN
   iret = DlgGet(...
   !Do something after closing (or not)
END IF
WinMain = 0
END FUNCTION WinMain
That's about all you need.
HTH
Jugoslav
