Software Archive
Read-only legacy content
17060 Discussions
R200 Enhanced photo not working in C#
Aaron_B_3
I'm trying to use the enhanced photo module inside of a C# project and am running into some trouble. Unfortunately I can't get any feedback from the SDK about what they error might be or what I am doing wrong. Has anyone got this module to work successfully in C#?
Here is how I load the module:
            PXCMSession session = PXCMSession.CreateInstance();
            short major = session.QueryVersion().major;
            short minor = session.QueryVersion().minor;
            Console.WriteLine("SDK Version {0}.{1}", major, minor);
            session.Dispose();
            PXCMSenseManager sm = PXCMSenseManager.CreateInstance();
            sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_COLOR, 640, 480, 30);
            sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_DEPTH, 628, 468, 30);
            PXCMEnhancedPhoto ep;
            PXCMPhoto photo = sm.QuerySession().CreatePhoto();
            pxcmStatus sts = sm.QuerySession().CreateImpl<PXCMEnhancedPhoto>(out ep);
            if(sts == pxcmStatus.PXCM_STATUS_NO_ERROR)
                Console.WriteLine("enhanced photo module created");
            sm.Init();
This results in the console displaying "enhanced photo module created" - presumably all is well.
Here is the code where I attempt to use the enhanced photo module to resize the depth:
                        photo.ImportFromPreviewSample(sample);
                        PXCMImage.ImageInfo info = photo.QueryReferenceImage().QueryInfo();
                        PXCMSizeI32 targetSize = new PXCMSizeI32(info.width, info.height);
                        PXCMImage depthFromPhoto = photo.QueryRawDepthImage();
                        PXCMPhoto resized = ep.DepthResize(photo, targetSize);
                        if(resized==null)
                            Console.WriteLine("image did not resize properly");
Here is the entire main:
static void Main(string[] args)
            session.Dispose();
           // sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_RIGHT, 628, 468, 30);
           // sm.EnableStream(PXCMCapture.StreamType.STREAM_TYPE_LEFT, 628, 468, 30);
            sm.Init();
            int frames = 0;
            while (frames < 60)
                // This function blocks until a color sample is ready
                sts = sm.AcquireFrame(true);
                if (!sts.IsError())
                    // retrieve the sample
                    PXCMCapture.Sample sample;
                    sample = sm.QuerySample();
                    if (frames == 59)
                        if (resized == null)
                    sm.ReleaseFrame();
                    Console.WriteLine("frame acquired");
                else
                    Console.WriteLine("Error acquiring frame");
                frames++;
            sm.Close();
            Console.WriteLine("CTRL-C to close...");
            Console.ReadLine();
Aaron_B_3
Update on this: This actually does work in some cases but not all. In the case where it does work it outputs a message about CUDA. Is there anyway to force this process only on the CPU?
edit: As a bizarre addition to this update, resizing the depth with the enhanced photo module works on my desktop computer with an R200 dev kit and an Nvidia card. EnhancedDepth does not work on this computer.
On my recently purchased HP Spectre X2 with a built-in R200 EnhancedDepth works but resizing the depth does not. Any suggestions or additional guidance as to what this module is doing would be appreciated. Here the platform it outputs to the console is OpenCL.
Thanks!
Xusheng_L_Intel
Need OpenCL 1.2 support for EP MW.
