Software Archive
Read-only legacy content
R200 SetDSMinMaxZ() fails with STATUS_DEVICE_FAILED
Henning_J_
Every time I try to use SetDSMinMaxZ(), it fails with PXC_STATUS_DEVICE_FAILED. Is that not implemented yet? Or is there some other problem?
I'm using C++, SDK version 6.0.21.6598, with the R200
  PXCSession *session = PXCSession::CreateInstance();
  PXCSenseManager *senseManager = session->CreateSenseManager();
  pxcStatus st = senseManager->EnableStream(PXCCapture::STREAM_TYPE_DEPTH, 480, 360, 30);
  if (st < PXC_STATUS_NO_ERROR)
    return -1;
  st = senseManager->Init();
    return -1;
  PXCCaptureManager *cm = senseManager->QueryCaptureManager();
  PXCCapture::Device *device = cm->QueryDevice();
  PXCRangeF32 depthRange;
  depthRange.min = 600.f;
  depthRange.max = 700.f;
  st = device->SetDSMinMaxZ(depthRange); // fails with PXC_STATUS_DEVICE_FAILED(-201)
John_M_9
I am having the same problem.  I have even tried querying the range, then setting it with the same values:
	// Read Range
	PXCRangeF32 range;
	range = dv->QueryDSMinMaxZ();
	// Set Range
	//range.min = 760;
	//range.max = rangemax;
	sts = dv->SetDSMinMaxZ(range);
	if (sts<PXC_STATUS_NO_ERROR)
		sm->Release();
		data = 5;
		return 5;
I find that it is failing when it is trying to set the minimum value:
        __inline pxcStatus SetDSMinMaxZ(PXCRangeF32 value) {
            pxcStatus sts = SetProperty(PROPERTY_DS_MIN_MAX_Z, (pxcF32)value.min);
When I QueryDSMinMaxZ I get range.min = 0.0 and range.max = 65535.0.  So, knowing that the minimum range is about 20", I tried setting it for 30" and still the same error...
Any help would be appreciated!  Thanks!
John
Henning_J_
hmmm...when I turned on the logging in the sdk_info.exe and tried again, I found the following:
ERROR - CameraException: Internal exception: DSDevice::setMinMaxZ can only be used before capture started (-201)
So, that means to use the SetDSMinMaxZ method, I have to create the Device myself, use SetDSMinMaxZ() on it, then use the SenseManager to start stream images? Well, at least that works. But it seems awfully complicated:
  PXCSession::ImplDesc desc1 = {};
  desc1.group = PXCSession::IMPL_GROUP_SENSOR;
  desc1.subgroup = PXCSession::IMPL_SUBGROUP_VIDEO_CAPTURE;
  PXCCapture* c;
  session->CreateImpl<PXCCapture>(&desc1, &c);
  PXCCapture::Device* device = c->CreateDevice(0);
  depthRange.min = 0;
  depthRange.max = 2000.f;
  pxcStatus st = device->SetDSMinMaxZ(depthRange);
    return -1;
    return -1;
Once I got the device anyway, is there a way to comfortably start stream from it directly?
John_M_9
Hi Henning,
Thanks for solving that.  It doesn't make much sense that we have to senseManager->Init() before we can get PXCCapture::Device *device, and then can't use *device->SetDSMinMaxZ(depthRange).
Of course, now that I can limit the range, I'm not so sure what it is good for - I could just ignore the values over depthRange.max all by my self...  I guess I was hoping it would scale the whole 16 bits between the min and max...
As a side note:  Thanks for turning me on to that logging tool.  I hadn't really noticed it.  Not terribly user friendly, but a help...
John
Henning_J_
Yeah, the whole design of the SDK around SenseManager and Device thing is weird.
That's exactly why I wanted it: so I can just copy the complete depth image into our internal data structures without needing to filter out the irrelevant values manually.
Yeah, it's well hidden, not really easy to use, but can be helpful, especially for some of the less obvious failures/error codes.
