Software Archive
Read-only legacy content
17060 Discussions
R200 camera has stopped functioning
DKryd
hello, my r200 stopped working this afternoon so i disconnected it and uninstalled the dcm and runtime. downloaded both again and begin the install of the dcm which ended without success giving me this error message.
Intel® RealSense™ Depth Camera Manager R200 Setup Wizard ended prematurely because of an error(s). error code : -3 To install this program at a later time, run Setup Wizard again. Click the Finish button to exit the Setup Wizard. tried twice again with same result. any ideas?
christopher_b_3
If you installed the optional runtime, then you likely have a newer version of the DCM than the SDK. You should have DCM vers 2.0.3.5319.
Run the sdk_info.exe in the bin folder to see what version your using.
DKryd
any idea what the correct firmware version is?
DKryd
i'm running into an issue with javascript samples on the sample browser. some samples work great while other samples [all javascript samples] ask to have the platform [microsoft edge] updated by downloading and running
intel_rs_sdk_runtime_webapp_7.0.23.8048.exe
which i do and then attempt to run the sample again and at that point receive the same update platform message.
like i said, some samples accept the platform as setup others request repeatedly for the update to be run.
christopher_b_3
What are you referring to as firmware ?
SDK version 7.0.23.8048
Depth Camera Manager Service ( in the camera tab of sdk_info.exe ) version 2.0.3.5319
From the download page :https://software.intel.com/en-us/intel-realsense-sdk/download
Step 1  installs the DCM version  2.0.3.5319
Step 2 installs the SDK
I recommend not doing the optional step. I ended up with a new version of the DCM ( like vers 2.14.xx or something ) and I _think_
it cam from this optional step - though I have not confirmed it.
DKryd
from the camera tab of sdk info there is a device 1 tab [without camera running] if you select it a firmware number is listed
i think this is the camera firmware.  what should that number be.
christopher_b_3
Hmm, still don't see what you are referring to. Here's what I see:
DKryd
does not surprise me that it does not show for you. this software is such a mish mash.  can not communicate if we both do not see the same thing
