Software Archive
Read-only legacy content
17060 Discussions
R200 infrared and depth
minxiang_y_
Hi guys.  I am confused about the infrared and depth images from R200 camera.
See the snapshots below:
Why infrared image is like that and so does depth image? These are different from F200 camera.
Xusheng_L_Intel
Could you explain more detail? What is the different between F200 and R200 as you observed?
SMali10
From what I can tell the F200 and the R200 use different techniques to calculate depth. The F200 uses a specific laser pattern that appears as a grid in the IR image, while the R200 is a speckle image, similar to the first generation Kinect.
Additionally the R200 has two IR cameras that calculate depth. Looking at those images, it looks like the IR image is from the left camera, and the depth image is from the right camera.
samontab
Valued Contributor II
I was going to answer the same thing.
They seem to use different IR emitters.
The F200 allows control over timing of the pattern, whereas R200 allows control over location of the pattern (to get better resolution at different depths). Interesting.
minxiang_y_
How could I clean the speckles for infrared?
Lesly_Z_
how to acquire a good quality in depth image?
samontab
Control lighting in the scene, control IR emmiter, and control exposure time.
Basically, R200 is a stereo camera, so it needs to see features in both sensors correctly to have a good depth image. If it is under or overexposed, you'll have a bad quality depth image.
Lesly_Z_
this is the image I am getting.
