Software Archive
Read-only legacy content
17060 Discussions
[RESOLVED] Cmd key bug in OS X when using the Develop tab
Carlos_M_2
This issue has been resolved in 3977.
---- original post ----
The Cmd key bug in OS X is back in 3972 version...
Bracket bug?  Any fix?
Carlos Mendes
Carlos_M_2
Carlos Mendes
Namık_Zafer_E_
You can use this extension below
https://github.com/redmunds/brackets-display-shortcuts
In Intel XDK, select Extension Manager, install "Display Shortcuts". After them, open help tab, select "Show Shortcuts". Then you can remove these shortcuts "Command-[" and "Command-]" by left click and selecting "Disable Shortcut". After disable, you can see below keymap.json
    "documentation": "https://github.com/adobe/brackets/wiki/User-Key-Bindings",
    "overrides": {
        "Cmd-]": null,
        "Cmd-[": null,
        "Ctrl-Alt-I": null
PaulF_IntelCorp
Thanks for that workaround, Namik.
