Software Archive
Read-only legacy content
17060 Discussions
[RETIRED] Build Tab (Online Build Targets)
PaulF_IntelCorp
IMPORTANT: As of July 10, 2017, the Intel XDK cloud-based build servers have been retired. The build system is no longer be available for use with any version of the Intel XDK. Your mobile app projects will still be recognized as Intel XDK mobile app projects and will continue to work within the Simulate tab. Additionally, the Test tab can still be used to push your app to App Preview for on-device testing. Please see the new Cordova Build Package export tool located on the Build tab for alternatives to using the now retired cloud-based Cordova build system (you must be running version 3900 or later to see the export tool).
IMPORTANT: In February, 2017, the Crosswalk Project was retired. Crosswalk 23 was the last version of the Crosswalk library produced by the Crosswalk Project team. You can continue to build with the Crosswalk library using Cordova CLI or PhoneGap Build, but no further updates to the Crosswalk library will occur beyond version 23 (FYI: the Crosswalk 23 library for Android is based on the Chromium 53 runtime release).
See the release notes for additional details and alternatives to the retired Intel XDK features > https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk <
Older versions of the Intel XDK (version 3759 and earlier), will look something like the following when you attempt to perform a build:
And will result in an error message similar to the following if you attempt to perform a build:
Versions 3900 and later will look like the following:
Ad
New Contributor III
Thanks Intel for making XDK the past years.
We have developed and build many Apps for Android and iOS!
Today we still use XDK as an IDE with all the tools like plugin management and app icons.
We use the Cordova export function and Adobe PhoneGap to build Android or iOS Apps
, and it works well.
Ad
PaulF_IntelCorp
We use the Cordova export function and Adobe PhoneGap to build Android or iOS Apps, and it works well.
You're welcome! Glad to hear this new process is working for you!!
R_M_
Any links or documentation about that "Cordova export function" you use?
PaulF_IntelCorp
R_M_
My Build tab appears empty on MacOS...
PaulF_IntelCorp
Please read the release notes > https://software.intel.com/en-us/xdk/docs/release-notes-information-intel-xdk < and update to the latest version of the XDK > http://xdk.intel.com <
