Software Archive
Read-only legacy content
17060 Discussions
Range of RealSense 3D Camera (R200)
Soonhac_H_
I'd like to use RealSense 3D Camera (R200) for outdoor applications. Could you let me know the range of R200 outdoors?
Thank you,
Soonahc
Colleen_C_Intel
Outdoor usage is highly dependent on lighting. We are not currently publishing any spec.
Soonhac_H_
holosand
I have tested the r200 outdoors. It does not work. No depth measured. Is there any mode of the r200 for ourdoor application?
Tiago_F_
I have not tested yet in outdoors but i read that, depending on the luminosity conditions, it can be up do 10 meters if the proper parameters to outdoor conditions are used.
kfind1
Hey I have some info to help you regarding using the R200 outdoors, I disabled the Emitter and set gain to 1 (was at 4) and exposure to between 1 and 5ms (1ms worked best in very bright direct sunlight) and I got really nice depth images outside. You could set gain to 1 and then enable auto-exposure using device->SetDSLeftRightAutoExposure(true)
