Software Archive
Read-only legacy content
17060 Discussions
Raw stream - Color and Depth
Oleg_K_1
I am trying to get a color picture and it's depth map, but when i switch from one to another (SDK: Raw stream C# - color/depth) i see the pictures i get don't correspond to each other (pixel x,y at color picture doesn't match to pixel x,y at depth picture). Is this the way it should be? Am i doing something wrong?
Thanks a lot,
Oleg
Oleg_K_1
For instance, this are 2 corresponding pics, color and depth, of the same scene. Is there any transformation/translation between the 2 streams?
Bryan_B_Intel1
Hi Oleg - Does this help? https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?manuals_coordinates_mapping.html
Oleg_K_1
Hi Bryan,
Yes, I think this will help, i'll try it.
Thanks a lot!
Oleg
samontab
Valued Contributor II
These images come from different cameras, located at different places, with different lenses, sensors, etc.
This results in a different region of the world being imaged into each camera.
If you want to to have a pixel to pixel corresponding images, you need to project one image into the other.
For example this creates a depth image that matches the color image:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?createdepthimagemappedtocolor_pxcprojection.html
You can also go the other way around, creating a color image that matches the depth image:
https://software.intel.com/sites/landingpage/realsense/camera-sdk/v1.1/documentation/html/index.html?createcolorimagemappedtodepth_pxcprojection.html
Oleg_K_1
Thanks, will try that too!
