Software Archive
Read-only legacy content
17060 Discussions
Re: Callback routine in mixed language programming
Jugoslav_Dujic
Valued Contributor II
IMO the simplest mechanism is to pass address of a Delphi callback function into a Dll. The callback need not be in Delphi DLL, but you must follow guidelines for mixed-language programming. STDCALL calling convention is kinda standard for mixed-language stuff, so your code should look something like:
SUBROUTINE MyFortranDll(..., fnCallback)
!DEC$ATTRIBUTES DLLEXPORT, STDCALL, ALIAS: "_MyFortranDll@XXX":: MyFortranDll
INTERFACE
   SUBROUTINE fnCallback(n)
   !DEC$ATTRIBUTES STDCALL:: fnCallback
   INTEGER n
   END SUBROUTINE
END INTERFACE
DO i=1, large_computation
   CALL fnCallback(i)
END DO
!---8<--Callback in Delphi: -----------
procedure DllProgressBar( nProgress: integer); stdcall;
{do something with progress indicator here}
end;
!---8<--Delphi's calling routine: -----------
procedure MyFortranDll(... fnCallback: pointer); stdcall; external "MyDll.dll";
MyFortranDll(... @DllProgressBar);
I don't speak Delphi best, so I might have made some syntax error,
but I hope you get the idea.
One final remark: if you have to call fnCallback from somewhere deep in the dll's calling tree, it's sufficient that you pass fnCallback through all arg-list declared as EXTERNAL. Only in the routine that actually calls fnCallback you'll need full INTERFACE.
HTH
Jugoslav
