Software Archive
Read-only legacy content
17060 Discussions
Reading resources
alfredodell
I have managed to write a custom binary resource to a .exe file.
I want to access the resource when I run the program.
I have tried using FindResource(NULL, IDR_name, RT_RCDATA)
but I get a 0 handle. This also happens when I replace RT_RCDATA by
any 16 bit number.
What call should I use to access the resource?
Jugoslav_Dujic
Valued Contributor II
Uh... been there once... let me see... yes, I got it on my disk. Well, the problem is that constant RT_RCDATA doesn't actually mean "any user-defined resource". The docs are rather unclear on that. Now, I don't recall the details about what the gotcha was, but the point is that you should "define" your resource type using an arbitrary ID (as with any control), store it to .rc file and use that ID instead of RT_RCDATA.
Here's the copy & paste of a simple app which stores its own source (ResExtract.f90) as a resource. It's a win32 app, though the principle is the same for any kind of application. Note that USERTYPE is a PARAMETER of arbitrary value (10); it's added to resource.h and resource.fd manually:
INTEGER FUNCTION WinMain(hInst, hPrevInst, lpCmdLine, nCmdShow)
!DEC$ATTRIBUTES STDCALL, ALIAS: "_WinMain@16"::  WinMain
USE DFWIN
IMPLICIT NONE
INCLUDE "Resource.fd"
INTEGER:: hInst, hPrevInst, lpCmdLine, nCmdShow
INTEGER:: hLGlobal, hResource, dwResourceSize, iSt
!String buffer to retrieve the resource (this code)
CHARACTER(LEN=1000)::  sVoidData; POINTER(lpVoidData, sVoidData)
!Obtain resource's handle:
hResource = FindResource(NULL, MAKEINTRESOURCE(Resource0001), MAKEINTRESOURCE(USERTYPE));
dwResourceSize = SizeOfResource(NULL, hResource);
iSt=GetLastError()
!Load resource into memory:
hlGlobal = LoadResource(NULL, hResource);
!Obtain a pointer from a memory handle and use it as
lpVoidData = LockResource(hlGlobal);
WinMain=1
END FUNCTION WinMain
!=8<=ResExtract.rc======================
// RT_RCDATA
Resource0001     USERTYPE   "ResExtract.f90"
!=8<=resource.h======================
#define     Resource0001     100
#define     USERTYPE          10
HTH
Jugoslav
