Software Archive
Read-only legacy content
17060 Discussions
RealSense Camera is not working
Gopal_singh_m_
Hey,
I tried my best to get input from my camera which was sent by you. My system configuration is:
processor: i5 3rd generatin 3230, i5-3230M 2.6 GHz with Turbo Boost up to 3.2GHz
4GB RAM
I am using visual studio 2013 update3 and my current operating system is windows 8.1 . I have installed intel sdk also. when i tried to run sample browser, my camera is not taking input. I tried my best to set configuration. My friend also helped to setup camera also, but it's not working.
Now what should i do??please help me
leon_m_
Is your camera attached to a a USB 3.0 port ?
Gopal_singh_m_
yes it is connected to USB 3.0 and one another thing my system is showing that it is connected, i mean when i see at connected device, this device is also showed as a connected device.
Colleen_C_Intel
Run sdk-info as admin (in the RSSDK) and submit the log here please.
Do you see a light on the camera?
How does it show in device manager (should show as 3 cameras)
Gopal_singh_m_
sorry, actually i was thinking that my USB port is 3.0 but it's not.
that's my fault that i was trying to operate it in USB 2.0. well sir when i connect it, it shows green light for a moment. and than goes away that light.
So sir what should i do now?
Colleen_C_Intel
The camera requires USB 3.0
Gopal_singh_m_
So what should i do sir?? any suggestion?
Jack_K_1
New Contributor II
Gopal,
I'm guessing from your processor's name that you're using a laptop.  Am I right?  Is the USB port you thought was 3.0 capable blue?  Who manufactured your system and when was it built?
Jack
Gopal_singh_m_
yes sir you were right. it is laptop. It's ACER E1-571-53234G50Maks  was built on 16/01/2013. and it doesn't contain blue port. I was thinking that one port is USB 3.0, when i was purchasing it, than i saw this information on a website that it contain's one USB 3.0 also, that's why i was thinking. but now i just checked in device manager also. it is USB 2.0. All laptop's port are 2.0
Any suggestion or any help if you can .
Carles_V_
If you won a NUC .... use it.
If not, I think the only solution you have is to buy a new laptop (computer, NUC, whatever) with an Intel 4th generation CPU and USB3 (Intel, for best chances to work).
Jack_K_1
New Contributor II
Gopal,
Assuming I found the correct manuals for your system on the Acer website, it looks like it does not have an ExpressCard slot, which is too bad because there is at least one USB 3.0 adapter (from StarTech) that might work.
I can see from the website why you thought your laptop had USB 3.0.
However, I don't think your system will work.  But, maybe I missed something.
I built an i5 NUC that is working with the camera; it's running Windows 10 and Visual Studio 2015.
Best of luck.
Jack
Gopal_singh_m_
Carles sir , i never won a NUC,  if there is anyway to win it or get it, please tell me. I will try my best, because this project is very important for me, barely i got this opportunity. So if there is anyway to get NUC or by working with intel, if i will get NUC let me know, please.
Thank you.
And Jack ketola sir, you mean if i use that NUC with i5 laptop which have window 10 with visual studio 2015, than i can keep working on this project.Am i right?but sir that NUC is out of my budget, can i get one from you? i will give back it to you
Jack_K_1
New Contributor II
Gopal,
I was trying to suggest that you could build an i5 NUC, and install Windows 10 and Visual Studio 2015 to save some money, since you can't use your laptop.
I'm not a vendor, and I don't have extra NUCs to lend.
Jack
samontab
Valued Contributor II
Well, in theory you should still be able to compile a working app in your machine. You will just not be able to test it even once :)
Gopal_singh_m_
No sir, no tutorial is working with that camera, but yes when i try to start them, except some tutorial(3D viewer,etc)my webcam of laptop is takin input. So basically my camera is not taking a small input.So how can i test that app sir?I didn't get you properly samontab sir
Carles_V_
The NUC's prizes was part of the first phase of the App Challenge. Sorry :-(
But you can always build a "cheap" computer with 4th generation and USB3 for 300-400 $.
Gopal_singh_m_
carles sir ,  300-400$ , it is around 20000-25000 indian rupees. this is costly , I can't afford it at all.
By the way thanks for information , thanks a lot.
samontab
This is just a thought, but it in theory it should be possible to have one machine with a camera attached to it, and having remote desktop connections to it, allowing developers without cameras or proper computers to develop apps using virtually any computer.
