Software Archive
Read-only legacy content
17060 Discussions
RealSense F200 running on Windows 10 VM issues
Ray_H_
Realsense F200 running out of Windows 10 VM using VMware Workstation 12
Has anybody been successful in getting this going? Everything works fine running out of Windows 10 on a base machine. However no luck with  VMware Workstation 12 and USB 3.0 configured correctly running a Windows 10 VM. The VM says that it sees the camera and says that all is working correctly, but the Hello option does not appear (as it does when running W10 out of a base machine). Maybe VMware needs to have something tweaked?? Everything is definitely USB 3 - base machine and hook to VM machine. Any suggestions. Thank you. Ray
Xusheng_L_Intel
We do not support VM and do not recommend run RealSense App under VM. Thanks!
