Software Archive
Read-only legacy content
17060 Discussions
RealSense Java Hand Joint Tracking Fails
Alberto_P_
I'm trying to get hand joints with Processing 2.2.1 using:
          if ( handConfig.IsTrackedJointsEnabled() ) {
            PXCMHandData.JointData hd = new PXCMHandData.JointData();
            sts = hand.QueryTrackedJoint(PXCMHandData.JointType.JOINT_CENTER, hd);
But QueryTrakedJoint() fails :
Error Log
# A fatal error has been detected by the Java Runtime Environment:
#  EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x00007ff8d13c171a, pid=828, tid=1912
# JRE version: Java(TM) SE Runtime Environment (7.0_40-b43) (build 1.7.0_40-b43)
# Java VM: Java HotSpot(TM) 64-Bit Server VM (24.0-b56 mixed mode windows-amd64 compressed oops)
# Problematic frame:
# C  [libpxcclr.jni.dll+0x171a]
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
j  intel.rssdk.PXCMHandData$IHand.PXCMHandData_IHand_QueryTrackedJoint(JLintel/rssdk/PXCMHandData$JointType;Lintel/rssdk/PXCMHandData$JointData;)Lintel/rssdk/pxcmStatus;+0
j  intel.rssdk.PXCMHandData$IHand.QueryTrackedJoint(Lintel/rssdk/PXCMHandData$JointType;Lintel/rssdk/PXCMHandData$JointData;)Lintel/rssdk/pxcmStatus;+6
j  HandTracking.draw()V+450
j  processing.core.PApplet.handleDraw()V+231
j  processing.core.PGraphicsJava2D.requestDraw()V+4
j  processing.core.PApplet.run()V+156
j  java.lang.Thread.run()V+11
v  ~StubRoutines::call_stub
Nacho_C_
I am having the same problem, calling QueryTrackedJoint crashes the program. I have tried different combinations following the documentation, but the result is always the same. Anyway, it looks like the Java wrapper is pretty messed up, lots of the code snippets from the documentation are wrong.
Is there any expected date for the next release of the SDK? Looks like there is no way of having a demo for the early submision  deadline based on Java.
Alberto_P_
+1
