Software Archive
Read-only legacy content
17060 Discussions
Realsense hand tracking sample program does not work.
Koki_T_
Hi everyone,
I've received the Realsense camera. I tried install the SDK.
But sample program of hand tracking does not work.
All other sample program is work. My PC speck meet requirements.
Please tell me any ideas, any suggestions.
Best Regards, Thanks.
Basaveswar_K_
What OS & Processor are you using ?
Avan_T
Min: Win8.1 Os, Intel Processor 3 Gen, Usb 3.0
Koki_T_
Hi, Basaveswar, and Avan.
Now I'm using a laptop PC installed Win 8.1 and i7-4710MQ, and USB 3.0 socket. I have tried to run all of sample programs in the Intel RealSense SDK 2014.
All other applications except Hand Viewer worked well, but only the hand tracking application didn't work. It i suddenly stops running at the same time when I start it.
Colleen_C_Intel
@Koki -  what language sample are you using?  What is the exact model number of your CPU?
Mikhail_N_Intel
Can you elaborate how it stops - any messages in the app or VisualStudio debugger, failing module/call stack?
Arun_D_
Hello
while running my hand viewer sample the device disconnects and stops. Then again when I  start it works for sometime and then again stops.
all the other samples are running properly.
Edit: https://software.intel.com/en-us/forums/topic/536848#comment-1807797 Somehow this solved my hands viewer problem.
jing_h_
Failed to pair the gesture module with I/O... when I presse start of hands viewer..
and the hand viewer sample doesnot work.
MartyG
Hi Jing,
I got that error when using a 3rd Generation Intel CPU in my PC.  When I upgraded the parts in my machine with an Intel i3 4th Generation CPU and a compatible motherboard, the error disappeared and the hand sample and all the other broken samples worked.
Koki_T_
Sorry to late reply, and thank you for all of your cooperation.
Recently I have solved the problem. That results from my mistake, my Win 8.1 PC named my user folder with "Kanji" characters when I set up my account by adding my Microsoft account. After I renamed my user folder with alphabets only, all of the samples worked fine.
Regatds,
