Software Archive
Read-only legacy content
17060 Discussions
Recommended method for attaching to serial peripheral (RFID reader)?
Michael_M_Intel
What is the recommended method for attaching Galileo, with IoT Yocto, to a serial device? I think my choices are the audio jack RS232 or a USB2serial cable attached to the USB host port. The latter requiring a driver.
Mike
Stewart_C_Intel
Galileo has two physical serial ports, one is connected to the 3 pin 3.5mm Jack, (serial0) and the other is connected to the TX/RX pins on the Arduino style header. So I would recommend the Arduino header, as this is 5V and the RFID reader is likely the same voltage levels. (my one is for example). The 3.5,mm jack is a true RS-232 port, ie with +/- signalling.
I think they are addressed as serial0 and serial1  in the Arduino IDE but I don't have an example handy to check.
Michael_M_Intel
I need RS232, so I'd have to go find an RS232 shield. I'll try the audio jack.
Brendan_L_Intel
There are Rx & Tx pins on the Galileo which connects to a UART (pin1&2). Note this is a TTL not pure rs232 interface. Although depending on your device connecting this may actually be better for you.
Using the serial rs232 may be a little dodgy since you'll get some garbage input to your device on boot etc...
Matthias_H_Intel
which you obviously could disable by removing the serial output in grub. Granted, it's slightly harder for the SPI output where you would need to reflash ...
Brendan_L_Intel
Yeah sure, if you recompile your own EDKII firmware, and then change the kernel parameters, you can stop the output on the rs232 port. But I wouldn't advise doing that without a dediprog handy!
Michael_M_Intel
I ordered an RS232 shield--sounds like that's the way to go.
Matthias_H_Intel
Quote:
matthias-hahn (Intel) wrote:which you obviously could disable by removing the serial output in grub. Granted, it's slightly harder for the SPI output where you would need to reflash ...
As far as I understand there is also a recover from SPI recovery file on USB (see document 330237-001US https://communities.intel.com/servlet/JiveServlet/previewBody/22475-102-3-26019/Galileo_BoardUserGuide_330237_001.pdf ch 2.5.4 "Force recovery"). Hence even w/o Dediprog you should be able to recover.
Brendan_L_Intel
Looks really cool, thanks for pointing that out!
Also instead of an rs232 shield, I'd personally go for a mPCIe card that does rs232 like this (obviously all depends on your use case!): http://linitx.com/product/jetway-3-x-rs232-1-x-rs232422485-mini-pci-express-card/13532
