Software Archive
Read-only legacy content
Registry issue
magneto_tn
I've been playing this online game for a year but apparently they updated something related to graphics.. because process monitor program show me several errors related to my graphic which is:
Mobile Intel 4 Series Express Chipset Family
so when i run the game, i get this errors after 5 to 10 minutes:
those registry keys are not found:
HKCU\\Software\\Intel\\Display\\igfxcui\\3D\\SRO_Client.exe NOT FOUND
HKLM\\Software\\Intel\\Intel Graphics Accelerator\\D3d Not found
HKLM\\System\\CurrentControlSet\\Hardware Profiles\\0000\\System\\CurrentControlSet\\Services\\iAlm\\Device0\\Attach.PrimaryDevice
HKLM\\System\\CurrentControlSet\\Services\\ialm\\Device0\\PruningMode
HKLM\\System\\CurrentControlSet\\Hardware Profiles\\0000\\System\\CurrentControlSet\\Services\\iAlm\\Device0\\Mon80861400\\DefaultSettings.DriverExtra
HKLM\\System\\CurrentControlSet\\Services\\ialm\\Device0\\CapabilityOverride
HKLM\\System\\CurrentControlSet\\Services\\ialm\\Device0\\Acceleration.Level
HKLM\\System\\CurrentControlSet\\Control\\GraphicsDrivers\\TemporarySettingChanges
I downloaded the last driver but those keys still missing and apparently the game need it.. please help me fix this problem if possible..
also i runned this test using intel graphic program, I hope it helps:
Intel Graphics Media Accelerator Driver for Mobile Report
Report Date: 8/31/2010
Report Time[hr:mm:ss]: 12:6:23
Driver Version: 6.14.10.5284
Operating System: Windows XP Professional Service Pack 3(5.1.2600)
Default Language: English (United States)
DirectX* Version: 9.0
Physical Memory: 3001 MB
Minimum Graphics Memory: 64 MB
Maximum Graphics Memory: 1024 MB
Graphics Memory in Use: 32 MB
Processor: x86 Family 6 Model 15 Stepping 13
Processor Speed: 1995 MHz
Vendor ID: 8086
Device ID: 2A42
Device Revision: 07
* Accelerator Information *
Accelerator in Use: Mobile Intel 4 Series Express Chipset Family
Video BIOS: 1625.0
Current Graphics Mode: 1280 by 800
* Devices Connected to the Graphics Accelerator *
Active Notebook Displays: 1
* Built-in Display *
Monitor Name: Plug and Play Monitor
Display Type: Digital
Gamma Value: 2.2
DDC2 Protocol: Supported
Maximum Image Size:
Horizontal: 12.99 inches
Vertical: 08.27 inches
Monitor Supported Modes:
1280 by 800 (60 Hz)
Display Power Management Support:
Standby Mode: Not Supported
Suspend Mode: Not Supported
Active Off Mode: Not Supported
Raw EDID:
00 FF FF FF FF FF FF 00 4C A3 45 4E 00 00 00 00
00 12 01 03 80 21 15 78 0A 87 F5 94 57 4F 8C 27
27 50 54 00 00 00 01 01 01 01 01 01 01 01 01 01
01 01 01 01 01 01 12 1B 00 88 50 20 10 30 10 30
13 00 4B CF 10 00 00 19 00 00 00 0F 00 00 00 00
00 00 00 00 00 23 87 02 64 00 00 00 00 FE 00 53
41 4D 53 55 4E 47 0A 20 20 20 20 20 00 00 00 FE
00 31 35 34 41 54 30 37 2D 48 30 31 20 0A 00 7E
* Other names and brands are the property of their respective owners. *
Quoc-Thai_L_Intel
For Graphics product support, you need to identify the correct chipset and refer to the product support page to get the correct driver. You can also check with manufacturer for product support. Below are some support links.
Graphics Product page-- http://www.intel.com/support/graphics/intelgm45/
Support Contacts: http://www.intel.com/feedback.htm?iid=ftr+contact
-Thai
magneto_tn
Hi thanks for the quick reply,
the chipset is: Mobile Intel GM45 Express Chipset..
christing
Thank you for sharing !
mbaupdates
Windows could not start because the following file is missing or corrupt:\WINNT\SYSTEM32\CONFIG\SOFTWARE
Top MBA Colleges in India
Business School Ranking
