Software Archive
Read-only legacy content
17060 Discussions
Removing plugin unknown error
Toby_R
Hi XDK Team,
Everytime I try to remove any plugin from my project I got this error
Sometimes after two tries I manage to remove one and then it blocks (can't remove any further) and I have to restart Intel XDK.
Just to clarify plugin.xml is there.
Is this a common problem? Is my project corrupted? Should I remove some temp data? If so then please point me which so I won't break things.
PaulF_IntelCorp
This is not a common problem, but it does happen. :( Usually it means your plugin directory is corrupted. Simplest fix is to:
  • make a list of your plugins
  • exit the XDK
  • delete the entire plugins directory inside your project
  • restart the XDK
The XDK should detect that they are missing and reinstall them. If it does not, then reinstall them manually from the list you made in step 1.
PaulF_IntelCorp
  • exit the XDK
  • restart the XDK
Toby_R
I have remade the whole project that time. today I had the same problem and followed your steps. It did the trick. Thanks for a fast and easy solution.
