Software Archive
Read-only legacy content
17060 Discussions
Repeated Android Build failure
Anjan_L_
My Android Build is failing repeatedly with the below exception and message:
FAILURE: Build failed with an exception.
* Where:
Script '.../YourData/platforms/android/CordovaLib/cordova.gradle' line: 128
* What went wrong:
A problem occurred evaluating root project 'android'.
> No match found
Please suggest what could be going wrong. I rebuilt another app that was built successfully last time and that build went fine. In this app the only new item is a Google Maps Widget that has been added and the corresponding Service bindings. The App is working well in emulator and in Debug mode.
Please help.
anjan
PaulF_IntelCorp
What is your list of plugins? If you remove any of the plugins, does this build error message go away?
Anjan_L_
I found the problem. In Build Settings I changed the App Version Code to 1.1 and that was causing issues. Reverting it back to 1 solved the problem.
josef_j_1
I have the same problem , i need App Version 3 and app version code 1.2
any solution ?
PaulF_IntelCorp
App Version Codes must be integers. It is an internal number used by the Google Play store to keep track of versions, it has nothing to do with the external version number of your app that you present to your users, that can be anything you want.
