Software Archive
Read-only legacy content
17060 Discussions
Report a BIOS Bug
xsecret2
Hello IDS,
What is the best (and faster) way to report some bugs we noticed in the latest Intel Desktop Board BIOS ? We really need a fix for the D955XBK Board, doing the following :
1/ Board doesn't POST with a Pentium 4 EE 3.4 GHz Engineering Sample. Latest BIOS do continuously a cycling POST CODE 22h -> 25h -> 28h while older BIOS do not generate a POST CODE at all
2/ The "Configure secondary SATA as : IDE/RAID" option is NOT available in the standard BIOS, we saw it in the ITK. We need it because the Silicon Image 3114 on the board is configured in RAID mode by default and is not able to work with a single drive attached. It should be set as "IDE" to work with a single drive.
Thank you for your support
Intel_Software_Netw1
Greetings from Intel Software Network Support.
The best thing to dowould beto submit the issue to the Intel Desktop Board Support team via the support mailform at http://support.intel.com. Theyarebest equipped to escalateyour issueto the appropriatehardware engineering contactsif required, or to indicatewhether any updates exist todaythat address the issue.
Lexi S.
Message Edited by intel.software.network.support on 11-15-2005 11:37 PM
