Software Archive
Read-only legacy content
17060 Discussions
S1200BT: Hardware error from APEI Generic Hardware Error Source: 1
Sorin_G_
We have a new Intel® Server System R1304BT with BIOS 41;1.16;1.16 running CentOS 6.4 which reboots or hungs randomly.
The issue occurs with other OS as well (i.e Debian, Ubuntu, SLES). Here is the crash dump during reboot:
<0>{1}[Hardware Error]: Hardware error from APEI Generic Hardware Error Source: 1
<0>{1}[Hardware Error]: APEI generic hardware error status
<0>{1}[Hardware Error]: severity: 1, fatal
<0>{1}[Hardware Error]: section: 0, severity: 1, fatal
<0>{1}[Hardware Error]: flags: 0x01
<0>{1}[Hardware Error]: primary
<0>{1}[Hardware Error]: section_type: memory error
<0>{1}[Hardware Error]: error_status: 0x0000000000000400
<0>{1}[Hardware Error]: node: 0
<0>{1}[Hardware Error]: card: 0
<0>{1}[Hardware Error]: module: 0
<0>{1}[Hardware Error]: device: 0
<0>Kernel panic - not syncing: Fatal hardware error!
<4>Pid: 0, comm: swapper Not tainted 2.6.32-358.18.1.el6.x86_64 #1
<4>Call Trace:
<4> <NMI>  [<ffffffff8150da18>] ? panic+0xa7/0x16f
<4> [<ffffffff81310959>] ? ghes_notify_nmi+0x239/0x240
<4> [<ffffffff81513c25>] ? notifier_call_chain+0x55/0x80
<4> [<ffffffff81513c8a>] ? atomic_notifier_call_chain+0x1a/0x20
<4> [<ffffffff8109cd1e>] ? notify_die+0x2e/0x30
<4> [<ffffffff81511919>] ? do_nmi+0x1e9/0x340
<4> [<ffffffff815111b0>] ? nmi+0x20/0x30
<4> [<ffffffff812d3c81>] ? intel_idle+0xb1/0x170
<4> <<EOE>>  [<ffffffff8109bee8>] ? hrtimer_start+0x18/0x20
<4> [<ffffffff81416718>] ? menu_select+0x178/0x390
<4> [<ffffffff814155f7>] ? cpuidle_idle_call+0xa7/0x140
<4> [<ffffffff81009fc6>] ? cpu_idle+0xb6/0x110
<4> [<ffffffff814f397a>] ? rest_init+0x7a/0x80
<4> [<ffffffff81c27f7b>] ? start_kernel+0x424/0x430
<4> [<ffffffff81c2733a>] ? x86_64_start_reservations+0x125/0x129
<4> [<ffffffff81c27438>] ? x86_64_start_kernel+0xfa/0x109
Any help in resolving this issue is appreciated.
Loc_N_Intel
Your post is in the wrong forum. Please contact the distributor or get help from the Intel(R) Server System page http://www.intel.com/content/www/us/en/server-systems/intel-server-systems.html
Thank you.
