Hello everyone,
I've installed RealSense SDK on my server (Windows Server 2012). But I do not see SDKVoiceServerST.exe in the process list. When I try to use voice recognition features, it doesn't work:
_source = session.CreateAudioSource();
_source variable is null and in the event log I can see the following record:
The description for Event ID 0 from source APP_NAME cannot be found. Either the component that raises this event is not installed on your local computer or the installation is corrupted. You can install or repair the component on the local computer.
If the event originated on another computer, the display information had to be saved with the event.
The following information was included with the event:
failed to create config file
if someone know how it can be fixed please let me know.
