Software Archive
Read-only legacy content
17060 Discussions
SETFONT doesn't set size correctly
Intel_C_Intel
I'm using SETFONT in a QuickWindows programme. With an argument of
"t'Arial'w9" the resulting font looks OK. When I change the width
parameter, however, only the width changes and not the height - the text
is squashed or stretched horizontally but stays the same size vertically.
The on-line documentation says that if only one of the height and
width is specified, then the one which was not specified will be adjusted
to maintain the correct aspect ratio for the font. This doesn't seem to
be happening - has anyone else seen this problem?
