Software Archive
Read-only legacy content
SEXIT
John_M_2
I'm booting tboot to a 3.11.10 linux kernel and it is indeed booting and pcrs, including 17,18 and 19 are being extended. Perhaps I just don't understand the sequencing - the part that has me perplexed is where tboot goes into SENTER and then starts over again and succeeds - although SEXIT is never run - specifically this section. I guess my question is - why would it restart tboot?
TBOOT: setting MTRRs for acmod: base=0xcf700000, size=0xd000, num_pages=13
TBOOT: executing GETSEC[SENTER]...
TBOOT: ******************* TBOOT *******************
TBOOT:    2014-05-16 12:00 +0800 1.8.1
TBOOT: *********************************************
TBOOT: command line: loglvl-all logging,serial,vga,memory vga_delay=1
TBOOT: BSP is cpu 0
TBOOT: original e820 map:
I've attached the full log
....JW
Colleen_C_Intel
The restart seems normal to me given the actions in the first tboot run are different than the second.. First gets to GETSEC[SENTER} and the second one moves on and gets to GETSEC[WAKEUP]. But confirming that - will get back to you.
John_M_2
Ok - well works as designed is perfectly fine - but I guess I need to read the docs closer - I thought it was going to run from SENTER to WAKEUP in one shot - I see the processors all doing the SIPI wakeup.
Also - when I've seen other logs I don't believe I've seen this action - is it just that they aren't that complete usually?
....JW
