void VirtualCpu::OnVmExit(CPU_STATE *cpuState)I need any thoughts about handling SMM in VT-x VMM. Thank you in advance.
ULONG_PTR exitReason = __vmread(VM_EXIT_REASON);
if(exitReason == EXIT_REASON_IO_SMI || exitReason == EXIT_REASON_OTHER_SMI)
ctrace("SMI "); // trace to serial port
// this code doesn't execute
The first question to ask is: do you trap on the transition into stand-by mode?
The VMM should turn VMX off before transitioning into S3. Moreover, when the system comes back from stand-by, the OSPM (the Windows OS) will get control, without going into the VMM first.
In some VMMs , they replace the OSPM wakeup routine with the VMMs, so that when the BIOS wakes up from S3, it will call the VMMs wakeup routine (the VMM will call the original OSPM wakeup routine).
Therefore, the problem might not be related to SMM. SMM executes by default outside the context of VMX, meaning that the VMM will not trap on SMM.
Is there a way to run SMM code inside guest ?
SMM is a special
operating mode that is transparent to the guest and OS in non-VMX mode.
The
PRM vol3B contains info about SMM in non-VMX mode (section 24.1) and in VMX mode
(section 24.16). A typical guest (in non-VMX mode) can not access SMM code.
The VMX section discusses how to set up a dual-monitor environment to handle
SMIs in a separate VMM.
Are you trying to use SMM in the dual-monitor VMX mode? What SMM functionality are you trying to access from a guest?
The SMM monitor should intercept execution of RSM in guest and properly finish working in SMM. The SMM handler code should be left unchanged if possible.
After reading the section 24.16 of 3B, I suppose these steps should be taken to enter in dual-monitor treatment:
- Set IA32_SMM_MONITOR_CTL MSR
- Set MSEG header
- Activate dual-monitor treatment by executing VMCALL opcode in VMX root mode
- Set VMCS for SMM monitor
- Switch to executive monitor. When SMI occurs, control will be transferred to SMM monitor
- Intercept RSM in guest; make VM-entry with "entry to SMM" VM-entry control set to 0
However this is only assumption. Can you describe the process of running SMM code in dual-monitor treatment more detailed?
