Software Archive
Read-only legacy content
17060 Discussions
SQLite storage plugin, can't insert data from a form
Melvin_R_
I have tried a lot a ways to trigger the insert query, but failed everytime, the closest one is the following code
       document.addEventListener("deviceready", onDeviceReady, false);
            function onDeviceReady(){
                var db = window.sqlitePlugin.openDatabase({name: "users.db"});
            function registrar() {
                nombre = document.getElementById("nombre").value;
                telefono = document.getElementById("telefono").value;
                correo = document.getElementById("correo").value;
                db.transaction(populateDB, errorCB, successCB);
            // create table
            function populateDB(tx) {
                tx.executeSql('DROP TABLE IF EXISTS data');
                tx.executeSql('CREATE TABLE IF NOT EXISTS data (id integer primary key autoincrement, nombre text, telefono integer, correo text)');
                tx.executeSql('INSERT INTO data (nombre, telefono, correo) VALUES ("'+nombre+'","'+telefono+'","'+correo+'")');
                queryDB(tx);
            // form the query
            function queryDB(tx) {
                tx.executeSql("SELECT * from data;", [], querySuccess, errorCB);
            // Display the results
            function querySuccess(tx, results) {
                var len = results.rows.length;
                alert("Datos: " + results.rows.length + " [should be 1]");
                    for (var i = 0; i < len; i++) { // loop as many times as there are row results
                    document.getElementById("output").innerHTML +=
                    "<table><tr><td>ID = " + results.rows.item(i).nombre +
                    "</td><td>telefono = " + results.rows.item(i).telefono +
                    "</td><td>correo = " + results.rows.item(i).correo + "</td></tr></table>";
            // Transaction error callback
            function errorCB(err) {
                alert("Error procesando Base de Datos : " + err.code);
            // Success error callback
            function successCB() {
                alert('Gracias por Registrarte');
This code is not inserting any data, but when I hit the button calling registrar() function with no data in the input, it launches the success callback. So I guees it registered when is blank.
What am I doing wrong here?
What I need is the user to register, and to show the last inserted row, fetching it from the database. Help please
I'm using this plugin https://www.npmjs.com/package/cordova-sqlite-storage
Rodrigo_M_1
New Contributor II
Melvin , I recommend you to use the Intel XDK Featured Plugins. There you can add the SQLite!
Go to Projects, Plugin Management, Add Plugins to this Project, Featured Plugins.  And Select the SQLite Native Storage that the Version is 0.7.14.
Another question: Which device are you trying to test it ?
Melvin_R_
I did that, and I'm testing with my Sony Xperia Z1, not an emulator.
Look, when I use the example below it runs fine, but when I try to call the function to insert from the form, doesnt work.
https://iphonedevlog.wordpress.com/2014/04/07/installing-chris-brodys-sqlite-database-with-cordova-cli-android/
So there must be something wrong with my code. I can't figure out what.
Rodrigo_M_1
New Contributor II
Definitely!
Check my template code:
// Wait for Cordova to load
var db;
// Cordova is ready
function onDeviceReady() {
    //This Enable/Disable the Screen Orientation
    intel.xdk.device.setAutoRotate(true);
    // This will create the Database.
    //db = window.sqlitePlugin.openDatabase("Database", "1.0", "Demo", -1);
    // options
      location: 0 // for iOS (0=Documents (default, visible in iTunes, backed up by iCloud), 1=Library (not visible in iTunes, backed up by iCloud, 2=Library/LocalDatabase (not visible in iTunes, not backed up by iCloud))
    // success callback
    function (msg) {
      //alert("success Creating DB: " + msg);
    // error callback
    function (msg) {
      alert("error on Create DB: " + msg);
    createDB();
function createDB(){
    db.transaction(function(tx) {
        //tx.executeSql('DROP TABLE IF EXISTS test_table');
        tx.executeSql('CREATE TABLE IF NOT EXISTS test_table(UserID integer, UserName text, TechID text, BranchID text, BranchCode text, DeviceID text, Password text, LogInDate datetime, TruckID text)');
    }, function(e) {
        alert("ERROR: " + e.message);
//Call this function to insert:
function InsertUserLog(pUserID, pUserName, pTechID, pBranchID, pBranchCode, pDeviceID, pPassword, pLogInDate, pTruckID){
        tx.executeSql("INSERT INTO TblUserLog (UserID, UserName, TechID, BranchID, BranchCode, DeviceID, Password, LogInDate, TruckID) VALUES (?,?,?,?,?,?,?,?,?)", [pUserID, pUserName, pTechID, pBranchID, pBranchCode, pDeviceID, pPassword, pLogInDate, pTruckID], function(tx, res) {
            //alert("insertId: " + res.insertId + " -- probably 1");
            //alert("rowsAffected: " + res.rowsAffected + " -- should be 1");
            updateProgressBar(50);
        }, function(e) {
Melvin_R_
Rodrigo M. wrote:
Definitely!
var db;
// Cordova is ready
    // options
    // success callback
    function (msg) {
    // error callback
    function (msg) {
    createDB();
    }, function(e) {
        }, function(e) {
can you give me a full example, I mean a full js and html file? I cant make it work.
Hamilton_Tenório_da_
Valued Contributor I
Try insert only one field of the table. See the result.
