Software Archive
Read-only legacy content
17060 Discussions
SR300 and FaceShift. I wonder if..
Scigor
We plan to test the SR300 with the latest version of Faceshift (before it closed its doors), considering that SR300 implements a F200 compatibility mode. But Faceshift don't recognize the camera neither the last SDK, and we think it's because it use a proprietary driver/plugin to communicate with the sensor (fs-1_IntelRealSenseSensorPlugin.dll) so if we can change this, it should also work with SR300.
The latest version of the driver for F200 was DCM 1.3.20.36232 with SDK 4.0.0.112526.
I was wondering if anyone has tried.
Any advice?
Scigor
josh_h_
I got it working.  Install latest SR300 drivers, but don't install latest SDK.  Use the 2014 SDK (4.0.0.112526) the one you're currently using.
Scigor
Thanks! I'll give a try, but last time I tried to downgrade the SDK (after uninstall the last one), the "lovely" Windows 10 said that I can't use that SDK with the last SR300.. But was 2 months ago.
There is a way to make coexist both of the SDK?
Thanks again,
Scigor
