Software Archive
Read-only legacy content
17060 Discussions
ScenePerception 32 bits init failed on surface pro 4 windows 10
dugua_y_
I am working with a R200 camera.
I am developping an augmented reality based on the scene perception module.
The application should run on surface pro tablet.
On a surface pro 3 windows 8.1 everything is ok.
But on a surface pro 4 windows 10 the application does not work.
The issue comes from the EnableScenePerception() function which fails.
Do you have any idea or known limitation on surface pro 4 or windows 10.
Thanks a lot,
Yohann
dugua_y_
After more investigation,
the scene perception module only works with the 64 bits version of the sdk on surface pro 4 windows 10.
I don't know why, is it a known problem or limitation ?
Yohann
