Software Archive
Read-only legacy content
17060 Discussions
Screen orientation not working when i test on device?
sinisa_k_
I am using Construct2 and i just cant make mine screen stop in portrait only mode when testing on iphone.
this is in my config.xml
<preference name="Orientation" value="portrait" />
but still on device screen rotates.
anyone can help?
Anusha_M_Intel1
As listed in this thread: https://software.intel.com/en-us/forums/intel-xdk/topic/583932#comment-1842741, it looks like the "cordova-plugin-screen-orientation-master" plugin works.
There is a workaround for orientation issues on iPad here: https://software.intel.com/en-us/xdk/faqs/cordova. Check out Question 1.
Here is the documentation for the cordova-plugin-screen-orientation-master plugin: https://github.com/gbenvenuti/cordova-plugin-screen-orientation. You can import it via the Plugin Manager in Projects Tab.
Plugin Management -> Add plugins to this project -> Third party plugins (from left list) -> Leave it at the default plugin source (Cordova plugin registry) and include this under plugin ID: cordova-plugin-screen-orientation
That is about it. Import and you are done.
sinisa_k_
@Anusha Muthiah (Intel)
This solution is not working anymore... i have iOS 9 on device and its not working.
Is there a proper way to lock orientation that works? ...and perhaps if its not too much to ask that intel can confirm as oficial?
thank you
PaulF_IntelCorp
@sinisa -- please see this FAQ for some help: https://software.intel.com/en-us/xdk/faqs/cordova#app-orientation -- also, make sure you are using CLI 5.1.1.
sinisa_k_
@Paul F. (Intel)
I have CLI 511 and i have cordova-plugin-screen-orientation installed and i'w set portrait mode in project build settings.
I use iPhone 6 for testing (this worked before, then i updated XDK to latest and iPhone to version 9.1) and in your intel XDK app for iphone my screen is still rotating.
Is there a something special that i need to do?
PaulF_IntelCorp
Did you include the appropriate calls to the orientation plugin? You need to do this in order to make that plugin do what you want. See the documentation for that plugin: https://www.npmjs.com/package/cordova-plugin-screen-orientation
sinisa_k_
Yes, i'w set: screen.lockOrientation('portrait');
As it was required but screen still rotates.
Here's the link where people say that they all have the same issue:
https://www.scirra.com/forum/viewtopic.php?f=147&t=164391&sid=48c9fef58703692c910379c71a3dff34&p=995833#p995833
In preview app it's not working but in build it does!? ...looks like app has a bug!
BR
S
PaulF_IntelCorp
It doesn't work on App Preview because third-party plugins cannot be utilized in App Preview... See these doc pages > https://software.intel.com/en-us/xdk/docs/lp-debugging
