Software Archive
Read-only legacy content
17060 Discussions
SecureBoot not booing signed binary?
David_F_2
I'm using a DH77KC and updated the firmware today (111).  Prior firmware was (108 from 2013 - and was allowing non-signed items to boot).   So now when I enable secure boot, it seems to be checking, only it's rejecting the binary MS signed the beginning of this month.   Is this firmware setup to only boot MS binaries and not MS signed third-party binaries?  I haven't tried booting Windows to see if it even allows that?
Also how does one reset the entire cmos on this system, the load defaults dosen't clear out all the NV Memory, if I remove the battery will it?
Thanks!!
BrianRichardson
This isn't the correct forum for motherboard support, but I might be able to help.
First, I recommend updating the firmware to the latest version:
https://downloadcenter.intel.com/download/27755/BIOS-Update-KCH7710H-86A-
That may help with the default value, along with providing the latest patches. It may also resolve the UEFI secure boot certificate issue. If not, you may have to enroll updated certificates manually. Sometimes these are delivered by Microsoft Windows Update when Secure Boot is enabled.
The updated Microsoft binaries might be signed against an older key. I recommended disabling secure boot and enrolling updated KEK/db entries for Microsoft & the UEFI CA (3rd party UEFI binaries). You can do this from the same setup menu used to turn secure boot on/off (look for a 'Custom' menu).
https://docs.microsoft.com/en-us/windows-hardware/manufacture/desktop/windows-secure-boot-key-creation-and-management-guidance ;
The Microsoft KEK certificate can be downloaded from: http://go.microsoft.com/fwlink/?LinkId=321185.
The Windows CA can be downloaded from here: http://go.microsoft.com/fwlink/p/?linkid=321192.
The UEFI CA can be downloaded from here: http://go.microsoft.com/fwlink/p/?linkid=321194.
David_F_2
Thanks, I had just updated the firmware to that latest version.  Anyway, I was able to get in to custom mode, but not install the certificates, no option to do that?
