Software Archive
Read-only legacy content
17060 Discussions
Segfault with asynchronous offload
aketh_t_
Hi
I am facing a segmentation fault problem when I try to perform asynchronous offload at a later point which I believe is the time when the function returned.
here is the code
function A
real :: WORKN(X,Y,Z)
!dir$ offload begin target(MIC:0)signal(1)out(WORKN)
   do k=1,km
           !Lots of code
!dir$ end offload
end function A
function B
real :: Dummy
! Do Whatever
end function B
program run
!$OMP PARALLEL DO DEFAULT(SHARED) !this OMP is dummy i.e num_blockblock is 1, can be removed
do iblock=1,num_blocks
      call functionA(iblock) !here is the async offload
enddo
!$OMP END PARALLEL DO
      call functionB(iblock) get segfault when B is running
enddo
end program run
