Software Archive
Read-only legacy content
17060 Discussions
Segmentation fault Using example 3_c_onboard_LED_blink
Mike_M_3
I opened the example "3_c_onboard_LED_blink" in eclipse, changed nothing to it. Built it and executed it.
In the console window i received the following. Not sure what a Segmentation fault is.
root@edison:~#
echo $PWD'>'
/home/root>
root@edison:~#
root@edison:~# chmod 755 /tmp/3_c_onboard_LED_blink;/tmp/3_c_onboard_LED_blink;e
xit
Welcome to libmraa
 Version: v0.5.0-12-g3898182
 Running on Some weird devboard that isn't recognised...
Segmentation fault
Brendan_L_Intel
Segmentation fault
Could you share with us the version of the OS/firmware on your edison board? A seg fault is a critical error, in this case caused by your board being unrecognied because of an invalid name in the DMI tables. This will cause galileo gen1 tables to be loaded and somewhere after cause a crash. mraa_init() returning non zero is a fatal error.
What's the output of:
cat /sys/devices/virtual/dmi/id/board_name
Brendan
Mike_M_3
<blockquote>What's the output of: cat /sys/devices/virtual/dmi/id/board_name</blockquote>
BODEGA BAY
Matthias_H_Intel
and the output of
cat /etc/version
in order to answer Brendans's other question on OS/firmware
Mike_M_3
edison-weekly_build_68_2014-09-08_13-49-07
Matthias_H_Intel
ok, so far everything looks good. What's the host OS where you run the Eclipse IDE?
Mike_M_3
Win7 64-bit.
Matthias_H_Intel
just tried on a Windows 8 x64 host. Everything working fine. So maybe you need to share some more info on how you ran it?
Compile output:
19:29:27 **** Rebuild of configuration Debug for project 3_c_onboard_LED_blink ****
Info: Internal Builder is used for build
i586-poky-linux-gcc "-IC:\\[...]\ide\\iotdk-ide-win/devkit-x86/sysroots/i586-poky-linux/usr/include" "-IC:\\[...]\\ide\\iotdk-ide-win/devkit-x86/sysroots/i586-poky-linux/usr/include/mraa" -Os -g3 -Wall "--sysroot=C:\\[...]\\ide\\iotdk-ide-win\\devkit-x86\\sysroots\\i586-poky-linux" -m32 -march=i586 -c -ffunction-sections -fdata-sections -o "src\\3_c_onboard_LED_blink.o" "..\\src\\3_c_onboard_LED_blink.c"
i586-poky-linux-gcc "-LC:\\[...]\\ide\\iotdk-ide-win/devkit-x86/sysroots/i586-poky-linux/usr/lib" "--sysroot=C:\\[...]\\ide\\iotdk-ide-win\\devkit-x86\\sysroots\\i586-poky-linux" -lmraa -o 3_c_onboard_LED_blink "src\\3_c_onboard_LED_blink.o"
"Run As" configurations:
Run output:
root@edison1:~# echo $PWD'>'
/home/root>
root@edison1:~#
root@edison1:~# chmod 755 /tmp/3_c_onboard_LED_blink;/tmp/3_c_onboard_LED_blink;
exit
Welcome to libmraa
Mike_M_3
For what it's worth, I can compile all examples successfully with no errors.
I can run examples 1,2, 8 & 9.
When i run examples 3,4,5,6,7 is where i get the Segmentation fault
Mike_M_3
I have the same., yet my output is
root@edison:~#
echo $PWD'>'
/home/root>
root@edison:~#
xit
Welcome to libmraa
Segmentation fault
Mike_M_3
I think a better question is, since this DK is for the Edison, why aren't the examples made for it?
Why would they not include the edison ?
typedef enum {
    MRAA_INTEL_GALILEO_GEN1 = 0, /**< The Generation 1 Galileo platform (RevD) */
    MRAA_INTEL_GALILEO_GEN2 = 1, /**< The Generation 2 Galileo platform (RevG/H) */
    MRAA_UNKNOWN_PLATFORM = 99 /**< An unknown platform type, typically will load INTEL_GALILEO_GEN1 */
} mraa_platform_t;
Mike_M_3
Another Tid bit, and then i will stop flooding this thread.
I headed over to github to try a example there, this is the one i tried.
https://github.com/intel-iot-devkit/mraa/blob/master/examples/mmap-io2.c
I get the same results.
Brendan_L_Intel
Hi Mike,
mraa_init() will get called either way, and the message you are getting is from that call which is failing. I'm not entirely sure why, whilst the libs in the eclipse build don't match whats on your board, for mraa_init() we're typically able to 'get away with it'. We're investigating further.
Matthias_H_Intel
if you copy over the generated binary - does this run on Edison?
Mike_M_3
Just so i am clear on what your asking.
The first thing i did was open a terminal and delete the files in the /tmp just to make sure...
In Project Explorer I clicked on the project then opened the debug folder, right clicked on the file 3_c_onboard_LED_blink and clicked copy. Then I clicked on remote system explorer. drilled down to the /tmp folder and pasted it there.
I then went back to the terminal tried to run it, permission denied. did a chmod +x 3_c_onboard_LED_blink, then tried it again and it ran but gave the same results.
Brendan_L_Intel
Can you clarify what baseboard you have plugged into the edison? Note we only support the arduino breakout board at this point.
Mike_M_3
I have the Intel Edison Breakout Board Kit Model EDI1BB.AL.K
I dont see how that has anything to do with it other than the fact that the output pin is wrong to flash a led.
Mike_M_3
I have received an answer to this. Maybe helpful to others who are using the edison mini breakout board like me.
mraa only supports the arduino breakout board, you cannot use it with the edison mini breakout board.
So for now we just sit and wait....
David_B_7
Thanks for posting this.  Do the C/C++ libraries work, or are we totally dead in the water regarding GPIO access without the Arduino board?
Mike_M_3
If your not using the Arduino board, And try to access the GPIO using libmraa It will compile just fine, but when you try to run it you will get a "Segmentation fault" in the terminal window and it just stops. So for now we have to wait until they fix it.
Tage_B_
I am also getting the Segmentation Fault when I am trying to run a simple Python program that toggles an output pin. I am using the small breakout board (Edison).
