Software Archive
Read-only legacy content
17060 Discussions
Sensor Accuracy
Jana_W_
Hi everyone,
for validation purposes we need a sensor which is able to measure the exact position of a human head (the distance between the head and the sensor will be around 0,8m (+/- 30cm). The measurement error should be below 1%. Could someone please tell me, if the  Intel®RealSense™ Developer Kit featuring SR300 can meet these requirements?
And could someone give me the excact accuracy values of the sensor?
Thank you very much,
Jana.
samontab
Valued Contributor II
No such thing as an exact number as different heads will give you different numbers.
Easiest thing will be to buy one and try it yourself to see if it meets your requirements.
In terms of range, you are at the far side, almost at the maximum range, so the detection will not be the best.
