Software Archive
Read-only legacy content
17060 Discussions
Senz 3D Depth Camera Issue
Lesley_T_
I have a real senz3d Camera and as you know it has both a depth and color stream. However, when using the RealSense SDK I only see the color stream. I confirmed this by running the Camera Viewer in the RealSense SDK. On running my older Perceptual Computing SDK a lot more streams are detected.
Since the new RealSense camera is not out yet, I can safely reason that people are using the RealSense SDK with their older camera or other depth camera. More over, I have seen RealSense demo's which use the older Senz3D camera, so I can also reason that the RealSense SDK does support this it.
PS: I have also downloaded the latest Creative Senz 3D driver (in-case that was an issue).
Thank you!
Huan_Z_1
I meet the same problem. would you mind sending me the link to install Perceptual Computing SDK 2013? ( ([email protected]))
Many thanks!
Huan
