This just hit me out of no where. I've been using XDK now for awhile and everything is going smooth. But today every build I've done has lost their launch icons and splash screens and they have been replaced with broken link icons. When I go ahead and build like normal they are missing from the app. This is a major set back. I tried from another work station and I'm getting the same error. I've also tried different version of XDK and are currently running the latest (this issue started with an older one). Does anyone have an advice. I'm getting a little worried.
- Tags:
- HTML5
- Intel® XDK
I fixed this issue. I will leave this up for anyone that is having the same issue. I added a set of "( )" to the file directory that caused an issue in the xdk file. Just make sure to check to see if its going to the right path.
