Software Archive
Read-only legacy content
17060 Discussions
SetFileName is not recording depth stream
varsha_h_
I'm using SetFileName() function for recording the depth stream. I have followed every thing mentioned in the documentation. Still I'm not able to save the depth streams to the specified file location.
Here's what I have tried so far:
void RecordORPlayback(pxcCHAR *file, bool record){
    // create a sensemanager instance
    //set file record or playback
    sm->QueryCaptureManager()->SetFileName(file,record);
    //Enable the stream
    PXCImage *depthIm;
    //initialize and record 300 frames
    sm->Init();
    for(int i =0; i<300;i++){
        //this function blocks until a depth sample is ready
        if(sm->AcquireFrame(true)<PXC_STATUS_NO_ERROR) break;
        //retrieve the sample
        PXCCapture::Sample *sample=sm->QuerySample();
        //work on the image sample->depth
        depthIm=sample->depth;
        //fetching the next frame/sample
        sm->ReleaseFrame();
    //closing
    sm->Release();
In main function I have called the 'RecordORPlayback' like:
    pxcCHAR *filename=(L"E:\\Output");
    RecordORPlayback(filename,true);
Still I'm not able to save the output(correct me if I'm wrong). Is there any other way to store the frames to a specified location?
Ron_S_Intel
Hi
In order to enable depth stream you should explicitly enable it using PXCSenseManager->EnableStream
I have updated your code below (line 13 under //Enable the stream)
    //Enable the stream
    sm->EnableStream(PXCCapture::StreamType::STREAM_TYPE_DEPTH);
    PXCImage *depthIm;
     sm->Init();
         sm->ReleaseFrame();
     //closing
     sm->Release();
Hope this helps,
Have a nice day,
Ron
varsha_h_
Hey Ron,
 I have mentioned it before. I have attached my code, take a look at it, and correct me if I'm wrong.
Have a nice day.
Varsha
