Software Archive
Read-only legacy content
17060 Discussions
Show list item on a details page
madson_g_
I am populating a list with json data. It´s working fine. Now I want to show the details of each item from the list on another page. How do I set the index to show exactly the corresponding item data?
function Lista(){
          $.ajax({
           type: "post",
           url: $server+"/check.php",
           data: dataString,
           success: function(result, jqXHR) {
           var eventos = $.parseJSON(result);
           $.each(eventos, function(index, item){
            //var nome = item.NOME;
            var list_item = '<a class="item item-thumbnail-left item-icon-right" href="#" id="list_item">';
            list_item += "<img src="+item.ARQUIVO+" id='thumb'>";
            list_item += '<h2>'+item.NOME+'</h2>';
            list_item += '<p>'+item.DATA+'</p>';
            list_item += '<i class="icon ion-chevron-right icon-accessory" id="ion-chevron-right"></i>';
            list_item += '</a>';
            if(!item.ERRO){
             $("#page_78_74").append(list_item);
             activate_page("#list");
            }else{
            navigator.notification.alert(item.ERRO, "", "Ops!");
            /* HERE WAS MY TRY TO SHOW EACH ITEM DATA, BUT IT SHOWS ALL THE VALUES AGAIN */
            $("#list_item").on("click", function(){
             var evento = '<h3 id="event_name">'+item.NOME+'</h3>';
             $("#event_infos").append(evento);
             activate_page("#detailspage");
          error: function(jqXHR, status){
           $("#situacao").html("<center>error</center>");
         new Lista();
Diego_Calp
Valued Contributor I
Hi Madson,
What I usually do is:
var list_item = '<a class="item item-thumbnail-left item-icon-right" href="javascript:viewItem('+item.ID+')" id="list_item">'
I'm assuming that you have an ID field key to identify the record, change this accordingly.
function viewItem(itemid){
    //select from database with itemid
    //populate the page
    //activate_page
Hope this helps.
Diego
Diego_Calp
Hi Madson,
    //populate the page
    //activate_page
Hope this helps.
Diego
madson_g_
I´m getting this message: Uncaught ReferenceError: Viewitem is not defined. Have tried to change somethings but had no success
Diego Calp wrote:
Hi Madson,
    //populate the page
    //activate_page
Hope this helps.
Diego
Pamela_H_Intel
Madison, in Diego's text he uses "viewitem" above the definition because he was just clarifying that you need the definition. The function definition must be processed before you try to use it, otherwise it will be undefined.
PaulF_IntelCorp
Madson -- change your reference to "viewItem" not "ViewItem"
madson_g_
I fixed it changing
function Viewitem(itemid){...}
to
window.Viewitem = function(itemid){....}
Even if I write the function before it didn´t work. But thanks anyway =)
Pamela_H_Intel
You define it with an uppercase 'V'. When you use it, are you using 'V'?
<edit> Ah, never mind. I see in your error message that you use upper case.
So . . . if you define it in a JavaScript file, do you include that .js in the head of your index.html?
madson_g_
Yes, it is. It's working right now with my latest answer. Thanks.
Pamela_H_Intel
Hmm . . . if you zip your entire project and send it to me in a private message I will take a look.
madson_g_
I am having an issue when I use a back button on header. When I press it, it works fine taking me back to list page. But when I click on another list item the last one is kept there. According I keep clicking on each list item, they are being added one below the other. It should show me just the last one clicked.
I have tried to empty(); the page but then nothing is showed. Just a blank page. How can I solve this issue?
Diego_Calp
Hi Madson,
Could you post the code you are using to fill the item's detail page?
madson_g_
Diego Calp wrote:
Hi Madson,
Ok, the code below and it is after the code that populates the list, inside success function that I posted in the beginning of the question.
             var dataStringID = "id="+itemid+"&get_id=";
             $.ajax({
              type: "post",
              data: dataStringID,
              success: function(resultID, jqXHR){
               var results = $.parseJSON(resultID);
               $.each(results, function(index, item){
                var evento = '<div class="widget uib_w_5 scale-image d-margins" data-uib="media/img" data-ver="0" id="file_div"><figure class="figure-align"><img src="'+item.ARQUIVO+'" alt="image" id="file"><figcaption data-position="bottom"></figcaption></figure></div>';
                evento += '<h4 id="event_name">'+item.NOME+'</h4>';
                evento += '<p>Evento</p>';
                evento += '<h4>'+item.LOCAL+'</h4>';
                evento += '<p>Local</p>';
Diego_Calp
Instead of
try with
$("#event_infos").replaceWith(evento);
append adds the html to DOM element, because of this you are getting acumulated items.
Diego
madson_g_
Diego Calp wrote:
Instead of
try with
Diego
It didn´t work. It keeps showing me the same event all the times. It works with $("#event_infos").html();
Thanks man!
Pamela_H_Intel
Madson,
Are you saying your problem has been solved using  $("#event_infos").html();?
Pamela
madson_g_
Madson,
Pamela
Talking about the back button issue? Yes.
