Software Archive
Read-only legacy content
17060 Discussions
Smooth for several objects
jarikus
I want to use the Smooth for palms and fingers from HandModule: example:
// create the smoother objects
void initRealSenseHand()
PXCDataSmoothing* smoother = NULL;
g_session->CreateImpl<PXCDataSmoothing>(&smoother);
// Creating Quadratic smoother - available options are [Spring, Stabilizer, Weightd]
m_smoother = smoother->Create3DQuadratic(0.5f);
void updateInfoFromRealSense()
// when you collect the tracking data - you smooth it by:
if(hand->QueryTrackedJoint(PXCHandData::JointType::SOME_JOINT_NAME,jointData) == PXC_STATUS_NO_ERROR)
PXCPoint3DF32 point = {jointData.positionWorld.x,jointData.positionWorld.y,jointData.positionWorld.z};
m_smoother->AddSample(point);
point = m_smoother->GetSample();
Question: I can use one smoother "m_smoother" for all parts (palms, fingers) or better create separate smoother for each part of hand? Sample:
PXCDataSmoothing::Smoother3D* m_smoother_palm_left
PXCDataSmoothing::Smoother3D* m_smoother_palm_right
Xusheng_L_Intel
You need not create different smoother if you use the same smooth algorithm for both hands.
