Software Archive
Read-only legacy content
17060 Discussions
Socket.io Android build using intel XDK
Rafael_M_1
Hello
I´m having some problem because the socket.io does´t work when I make the 'Cordova Hybrid Mobile App Platforms' in the Xdk. It works perfectly when I run in the emulate tab and also run in a preview through the intel app in the phone .
Mention that the socket works when build in 'Legacy Hybrid Mobile App Platforms'
Many thanks
Amrita_C_Intel
Did you try building with Legacy build?
Rafael_M_1
Hello
Thanks for the reply.
Yes I build with 'Legacy build' and the sockets work but does´t work properly is the JQmobile. The app looks very small and when I rotate it crashes.
When I build with 'Cordova Hybrid Mobile App Platforms' everything works fine unless the sockets
Amrita_C_Intel
Can u post a simple example code that we can try?
